Audacity doesn't check its temp folder when launching. It looks for AUTOSAVE files in the AutoSave folder. If the temp folder contains AU files but there is no AUTOSAVE file, Audacity will not recover anything when you restart it.
So we have the issue of what does Audacity do when confronted with potentially hundreds of AUTOSAVE files in the Recycle Bin - unless Audacity only sends one AUTOSAVE file to the Recycle Bin when you close without saving. Then other users will pop up and say why did you not preserve the previous AUTOSAVE file when the cat pulled the cord on my computer and the crash wiped the AUTOSAVE file.
And what happens if user right-clicks Recycle Bin on the Desktop > Empty Recycle Bin? Audacity won't intervene to stop the deletion.
You did not export backup WAV files or save incremental stages of your project as you went along.jaja714 wrote:Please do not let the tragic loss of my precious recording be in vain!
I think the only way to be safe from all complications and subsequent user errors if you mistakenly close a project without saving is to have an option for Audacity to always open with its last contents restored. It costs no more disk space than storing files in the Recycle Bin.
