aup. files windows
roosteralexy
aup. files windows
Post by roosteralexy » Fri Aug 29, 2014 5:46 pm
When i save my files they are saved in an aup format. How do i open the song as a single piece?
Re: aup. files windows
Post by kozikowski » Fri Aug 29, 2014 6:44 pm
That's an Audacity Project manager text file. To get a real sound file you have to Export one. if you need an MP3, you also have to install separate Lame software.
http://manual.audacityteam.org/o/man/fa ... .html#lame
http://manual.audacityteam.org/o/man/au ... jects.html
