No playback sound. [SOLVED]
mjschu
Post by mjschu » Mon Aug 25, 2014 8:22 pm
Hello,
I just installed Audacity v 2.0.5 on Windows7 and it seemed to work great. I noticed I needed to add Lame V 3.99 to export audio in mp3 format. After installing Lame, Audacity will no longer play back. The moving curser and the audio bars work but there is no sound. I did export a 3 minute section of a 2 hour digital recording from a Sony IC recorder and the exported file was great. My only problem is hearing the recording in Audacity so I can establish the section I want to keep. Can you help me?
Myron
Re: No playback sound.
Post by kozikowski » Mon Aug 25, 2014 11:14 pm
They should have nothing to do with each other.
Make sure Audacity is still sending sound to your speakers or headphones in the Device Toolbar.
http://manual.audacityteam.org/o/man/de ... olbar.html
Also make sure your playback volume slider (by the speaker) is all the way up.
http://manual.audacityteam.org/o/man/mixer_toolbar.html
I'm going to assume you're not trying to play a silent clip.
mjschu
Post by mjschu » Tue Aug 26, 2014 4:19 pm
THANK YOU KOZ!!
The Audio Host was set at MME and the only available Output Devise was Digital Audio.
When I changed the Audio Host to Windows WASA the Output Devise changed to Speakers.
IT WORKS!
mjschu
