retrieving music files
johnd675
Post by johnd675 » Fri Aug 22, 2014 6:23 am
Need help.i recorded a lot of songs from old cassettes to computer using audacity 2.x.i recorded a side at a time of music{just pressed the record button and let the side play) than saved the file for a later date.when i went to retrieve the music to edit i only could retrieve small samples of a song.audacity had saved all music into small samples.how do i retrieve the whole song or whole side of the cassette i recorded?any help would be much appreciated
Re: retrieving music files
Post by steve » Fri Aug 22, 2014 11:45 am
Audacity saves "projects", not ordinary audio files.
To create an ordinary audio file you must "Export".
Please see here for more details: http://manual.audacityteam.org/o/man/fa ... lternative
