how to separate streaming audio in two
Buckaroo01
Post by Buckaroo01 » Wed Aug 20, 2014 8:58 pm
I am using windows 7 with Audacity 2.0.5 and recorded 2 hours of streaming audio. Now I want to separate this into 2 or 3 audio projects based on type of music. How do I do this.
Thanks
Re: how to separate streaming audio in two
Post by kozikowski » Thu Aug 21, 2014 2:07 am
How did you save the work? MP3?
Buckaroo01
Post by Buckaroo01 » Thu Aug 21, 2014 3:49 am
Yes, it was saved as a MP3
Post by Gale Andrews » Thu Aug 21, 2014 5:06 pm
Buckaroo01 wrote:I am using windows 7 with Audacity 2.0.5 and recorded 2 hours of streaming audio. Now I want to separate this into 2 or 3 audio projects based on type of music. How do I do this.
If you saved an Audacity project, open the AUP file rather than import the MP3 again. MP3 is lossy so you threw quality away by exporting as that. To save a backup of a recording, export as WAV.
If you only have the MP3, drag it into Audacity, label the points where the songs change genre, then File > Export Multiple... . See Splitting a recording into separate tracks - Audacity Manual .
Robert J. H.
Post by Robert J. H. » Thu Aug 21, 2014 7:35 pm
Why so complicated?
I open a song, select the part that I want and press Ctrl-x (or c).
Then, Ctrl-n for a new project instance and Ctrl-v to paste the clip.
Post by kozikowski » Thu Aug 21, 2014 9:14 pm
First sentence:
The following tutorial demonstrates one method for dividing a recording into separate songs for export...
Buckaroo01
Post by Buckaroo01 » Sat Aug 23, 2014 3:27 pm
Thanks for all the great replies, I really appreciate the information !!!
