Cant use the save product in Sam 422
DjByker
Post by DjByker » Tue Aug 19, 2014 10:04 pm
Was tryin to edit a song I converted from youtube to a MP3 n Sams wouldn't load it
any ideals on what the set up I need to correct this issue
thanks
Byker
Re: Cant use the save product in Sam 422
Post by steve » Tue Aug 19, 2014 10:56 pm
To create a file that can be used in other programs you need to "Export" the song.
See here for details: http://manual.audacityteam.org/o/man/ex ... audio.html
For support with SAM 422, please consult their web site.
