cannot record directly on surface pro 2 system [SOLVED]
Sam Spade
Post by Sam Spade » Tue Aug 19, 2014 7:02 pm
Audacity 2.0.1 for
windows 8.1
Microsoft Surface Pro 2
I am trying to record sound streamed from a web-site.
I am unable to record any sound unless the web-site sound plays over the speakers and is picked up by the microphone.
I want to be able to directly record the sound. If I turn off the microphone using control panel no sound is recorded.
I am able to do this on my desktop systems running xp and 7 using audacity 2.0.1 but have no success with the surface pro 2.
any assistance will be greatefully appreciated.
Re: cannot record directly on surface pro 2 system
Post by steve » Tue Aug 19, 2014 7:32 pm
Have you tried using WASAPI as described here in the manual: http://manual.audacityteam.org/o/man/tu ... ndows.html
Sam Spade
Post by Sam Spade » Wed Aug 20, 2014 4:35 am
Bingo!!! Right on the money. Even though the link given did not correctly name the options on the devices and input boxes I was successful with my first try. Thank you for your kind and quick response.
Sam (Jim)
Re: cannot record directly on surface pro 2 system [SOLVED]
Post by Gale Andrews » Wed Aug 20, 2014 4:43 pm
Sam Spade wrote:The link given did not correctly name the options on the devices and input boxes
It can't possibly do that, given the variety of device names ;) Glad you can record now.
And I strongly recommend updating to the latest Audacity 2.0.5: http://audacityteam.org/download/windows .
