Audio Track is almost flat
Buckaroo01
Post by Buckaroo01 » Mon Aug 18, 2014 10:23 pm
I just downloaded Audacity and when I attempt to record streaming audio the Audio Track window shows very little movement and is almost flat. How do I correct this problem.
Thanks
Re: Audio Track is almost flat
Post by steve » Mon Aug 18, 2014 10:32 pm
First thing to do is to check your set-up.
If you are on Vista or later, I'd recommend using the WASAPI method described here: http://manual.audacityteam.org/o/man/tu ... ndows.html
