Hi, and thanks in advance for viewing and responding.
Basically, I want to take one track. A sample track if you will, and then have all my other audio tracks match up as closely as possible with this original track. Match up in terms of volume mostly, just tweaking a bit.
Does anyone know if Audacity is capable of doing this? Or do I need other software?
Editing Multiple Tracks
Re: Editing Multiple Tracks
Does this topic answer your question? http://forum.audacityteam.org/viewtopic ... 10#p249610
