Recording Radio Show w/Windows 8.1
PrinceSkip
Post by PrinceSkip » Thu Aug 14, 2014 5:06 pm
Is there an easy way to download a sports radio show on AM/FM radio? Thanks for any help provided.
Re: Recording Radio Show w/Windows 8.1
Post by kozikowski » Thu Aug 14, 2014 5:35 pm
To download it, someone would have to post the sound files on a server. I have a music system with a radio in it. I connect the stereo line-out to the computer line-in and record it in Audacity.
Most radios don't have stereo line-out and most newer computers don't have stereo line-in, but that's the way. You can use a Walkman type personal music player if it has a headphone connection and a tuner, but you can't connect that to most laptops.
http://www.kozco.com/tech/audacity/pix/ ... Mic-In.jpg
You can instead use a USB sound adapter such as the UCA-202.
http://www.kozco.com/tech/audacity/pix/ ... Lenovo.jpg
Post by kozikowski » Thu Aug 14, 2014 6:14 pm
Oh, yes. Some shows stream live and you may be able to capture them with Self Recording.
http://manual.audacityteam.org/o/man/tu ... puter.html
But don't depend on sporting events doing that. Their blackout services are legendary.
Post by kozikowski » Thu Aug 14, 2014 6:16 pm
And another note. Don't depend on AM radios working next to computers. Computers produce a healthy buzz on the AM band. You may need a long cable to connect them. Koz
