Picked up a USB condenser for some home stuff and it just won't work with audacity.
Is there something I'm missing here?
Won't recognize a USB mic.
Re: Won't recognize a USB mic.
Does Windows see it? It has to show up in Windows Control Panels before Audacity gets it.
Any marks on it? Maker? Part numbers?
