effect of the muffled music
Do you know how to do the music at some point was muffled, like from behind the wall?
Re: effect of the muffled music
Try Effect > Equalization and make it look like the attached.
- Attachments
- Screen Shot 2014-08-11 at 3.43.47 PM.png (64.03 KiB) Viewed 455 times
or the Low Pass filter: http://manual.audacityteam.org/o/man/lo ... ilter.html
It can be progressively-muffled with this variation of Steve's code in the Nyquist Prompt ...
http://forum.audacityteam.org/viewtopic ... 73#p220273
If you reverse the track then apply the code , (then reverse it back) , it gradually becomes less muffled,
similar to ... https://soundcloud.com/glitchhop/amb-get-loose#t=2:33
Code: Select all
(setq start-freq 22000) ; cannot be greater than 1/2 the sample rate
(setq end-freq 200)
(setq passes 6) ; more passes for a steeper filter cut-off
(setq sweep-type 0) ; 1 for a linear sweep, 0 for exponential sweep
(let* ((nyq (/ *sound-srate* 2.0))
(f0 (max 0 (min nyq start-freq)))
(f1 (max 0 (min nyq end-freq))))
(if (= sweep-type 0)
(setf lpfreq (pwev f0 1 f1))
(setf lpfreq (pwlv f0 1 f1)))
(dotimes (i passes s)
(setf s (lp s lpfreq))))
