Keys
SpexY
Keys
Post by SpexY » Mon Aug 11, 2014 5:54 pm
Hello, I am doing YouTube and I want Audacity to be my voice recorder.
However, I want it to play a voice file by pressing a certain key on my keyboard.
Is this possible?
Sincerely,
SpexY
Re: Keys
Post by steve » Mon Aug 11, 2014 6:01 pm
SpexY wrote:However, I want it to play a voice file by pressing a certain key on my keyboard.
Piano keyboard: No, not without (unknown to me) additional software that may offer that ability.
Computer keyboard: Spacebar to start/stop playback.
Perhaps a more suitable program might be Ableton Live.
SpexY
Re: Keys
Post by SpexY » Mon Aug 11, 2014 6:03 pm
Thanks but that is not how i meant
(sorry for not saying what I meant)
I mean I want to press a Keyboard key that will play a recording, not a file.
Sorry that I got mixed up.
Thanks again
SpexY
SpexY
Re: Keys
Post by SpexY » Mon Aug 11, 2014 6:05 pm
I don't think my posts are posting, but that is not what I meant, I meant that if I pressed a keyboard's key, would it start recording my voice?
So, for example
If I pressed F8, a recording would start?
waxcylinder
Re: Keys
Post by waxcylinder » Mon Aug 11, 2014 10:17 pm
Moderator note: your posts are posting - but unfortunately we have had to adopt a moderation queue to avoid a flood of spam, most annoying, some unpleasant and some downright dangerous.
Re: Keys
Post by kozikowski » Mon Aug 11, 2014 10:27 pm
I'm going to read between the lines. You need a special key because you have other sound production software running at the same time on your computer. That's probably a bad idea because Audacity doesn't share it's sound channels very well. It's the same reason that Audacity doesn't always like to record Skype. Two programs fighting for the same channels.
Re: Keys
Post by Gale Andrews » Wed Aug 13, 2014 7:20 pm
I think you want what are called "global shortcuts" in Audacity. Tell Audacity to use F8 as a global shortcut for recording, then you can press F8 when you are in your web browser and Audacity will start recording without you needing to switch to Audacity to start the recording.
If I guessed correctly, Audacity can't do that yet - it is a feature request.
