Need Help with Bit Rate
Pooka218
Post by Pooka218 » Sat Aug 09, 2014 7:04 am
I have tried to figure out how to set the bit rate and I cannot seem to find it. I need my audio to be 192 Kbps and I cannot seem to locate how to change this. I need to submit work to a client right away and I need to find out how to do this. Please help! Thank you in advance.
Re: Need Help with Bit Rate
Post by kozikowski » Sat Aug 09, 2014 7:21 am
You only get to set bitrate in one of the compressed formats such as MP3. The uncompressed formats such as WAV are fixed.
File > Export > MP3: Options...
Audacity doesn't naturally export MP3. To do that, you have to install the Lame software. To do that you have to tell me what kind of computer you're using.
Pooka218
Post by Pooka218 » Sat Aug 09, 2014 8:11 am
Hello Koz! Thank you for getting back to me. I'm using Windows 8. I already have the software installed to convert files to MP3's I just don't know how to change the bit rate to meet the client's specifications. The files are all 128 Kbps :(
Post by kozikowski » Sat Aug 09, 2014 11:27 am
If the process in my other post didn't work, you should tell me what version of Audacity you have.
Help > About.
Pooka218
Post by Pooka218 » Sat Aug 09, 2014 4:06 pm
Hi Koz, Thank you again for getting back to me. When I go to save the file as an MP3 it doesnt ask me for any options. I am so lost. I am running version 2.0.5
Pooka218
Post by Pooka218 » Sat Aug 09, 2014 4:07 pm
Disregard that last post I found what you were talking about. Wow mental moment, I never saw that "options" button there. Thank you so much for your help! I appreciate it!
