SKYPE RECORDING LEVELS LOW
Craigah128
Eh I'm running Windows 8.1 (which has never been a problem) on my PC and just today am having problems with recording audio. Today we are trying something different - a podcast - and as you can guess we are looking to have the best possible audio recording for our situation. Anyway, at first I was just going to use FRAPS to record the audio as it usually works fine, but when I recorded the audio my microphone is perfect, yet my friends on skype - although I can hear them perfectly through my speakers - their inputs are very low that I cannot hear them in the recording. This happened also when I tried it on Audacity which i just downloaded today. Any help on how to get their levels up on the recording, or sort the problem?
Re: SKYPE RECORDING LEVELS LOW
Skype recording is more of an adventure than you think. You are probably recording the Skype echo cancellation service, not the real thing.
http://www.pamela.biz/en/products/
Pamela is paid software, but works very well. The lower two licenses are intentionally crippled in order to make you buy a paid license.The best way to record Skype is to use software that is specifically designed for the job, such as "Skype Call Recorder" http://atdot.ch/scr/ (Free, open source software) or "Pamela" (commercial non-free).
