Keystroke recorded at beginning of take (append record)
lostramblin
Post by lostramblin » Mon Jul 28, 2014 2:24 pm
Hey they folks :
Using Audacity 2.0.3 on a Win 8.0 64 bit... recording on a samson c01u USB condenser
I use audacity for recording VOs for my video projects.
I like to use append record to keep the waveform in one track...
however, i noticed that the microphone picks up on the keystroke. Leaving a nice keyboard click sound at the beginning of all my takes.
I tried shortening the keystroke to just "R", hoping that the issue would be diminished... however it still remains.
Is there a way to add a short delay to the recording beginning? If I can start recording 200ms-500ms after the button press, I likely won't hear the keyboard.
Or is there another solution I'm missing?
Thanks for the help!
Re: Keystroke recorded at beginning of take (append record)
Post by kozikowski » Mon Jul 28, 2014 6:22 pm
You know how to edit the clicks out in post production, right?
It doesn't have to be a keyboard shortcut. You can do it with the mouse, too. Transport > Append Record.
Post by kozikowski » Tue Jul 29, 2014 8:25 am
If you're on a laptop, you can use the touchpad and not make any noise at all.
