Unbalanced stereo channels [SOLVED]
snowstorm
Post by snowstorm » Fri Jul 25, 2014 1:51 pm
I am using Windows 8.1 and Audacity 2.0.5 version
I recently taped video clips and extracted sound tracks;video was recorded in stereo mode
Using a Sony CX520V
As shown in the Meter Tool Bar ,t :oops: he left channel is showing a 'lounder sound' than the right channel
Is it possible to synchronized both channels.....
Any suggestions would be appreciated
Thanks
snowstorm
Reason: Fixed typo in topic title
Re: Unbalanced strereo channels
Post by Gale Andrews » Fri Jul 25, 2014 2:07 pm
You can use Effect > Normalize... with "Normalize stereo channels independently" enabled to give left and right the same peak volume.
DVDdoug
Forum Crew
Post by DVDdoug » Fri Jul 25, 2014 6:03 pm
If Gale's suggestion doesn't work,* you can click the little drop-down arrow to the right of the waveform and select Split Stereo Track.
Once you've don't that, you can use the Amplify effect on the tracks independently. Do this by ear. It's generally better to reduce the volume of the loud channel rather than boosting the quiet channel because the quiet channel may have a few short-term peaks that get boosted into distortion.
* The peak levels don't correlate well with loudness so normalizing the channels separately to match the peaks at 0dB, may not work. But since this was a camcorder recording, I expect Gale's suggestion WILL work.
Post by Gale Andrews » Sat Jul 26, 2014 11:37 am
DVDdoug wrote:If Gale's suggestion doesn't work,* you can click the little drop-down arrow to the right of the waveform and select Split Stereo Track.
Just to clarify, the short-term peaks should not get boosted into digital distortion (above 0 dB) unless you explicitly enable "Allow Clipping" in Amplify. But even if those peaks stay at or just below 0 dB they could still sound distorted when played in your player.
If the result was too quiet after reducing the volume of the loud channel you could then use Amplify on both channels, but any peaks in the louder channel may prevent you amplifying further. If that happens you will have to reduce the peaks using Compressor .
snowstorm
Re: Unbalanced stereo channels [SOLVED]
Post by snowstorm » Mon Jul 28, 2014 5:24 pm
Many thanks to DVD doug and Gale
I applied the normalized effect and it worked perfectly
Thanks
snowstorm
