Local volume adjustment
ElGoog
Post by ElGoog » Tue Jul 08, 2014 11:24 am
I am using Audacity 2.0.5 on Windows 7 64bit. I have the problem when i change playback volume in audacity it also changes the volume of windows. How can i fix this? Could not find anything related to it in settings.
Re: Local volume adjustment
Post by Gale Andrews » Tue Jul 08, 2014 12:31 pm
ElGoog wrote:I am using Audacity 2.0.5 on Windows 7 64bit. I have the probelm when i change playback volume in audacity it also changes the volume of windows. How can i fix this? Could not find anything related to it in settings.
The Audacity output slider directly controls the hardware's "Device" slider in the system rather than applying independent software gain to the current level of the device. It's a feature request for it to have an option to do the latter.
If you would like to make the Audacity playback volume quieter without affecting the system volume, you can do that by left-clicking the speaker icon by the system clock, then click "Mixer", then turn down the Audacity slider.
You may have to play some audio in Audacity before the Audacity slider appears in the Windows volume mixer.
ElGoog
Post by ElGoog » Tue Jul 08, 2014 1:53 pm
Oh so if i install an older version of audacity i can change the volume directly from audacity without affecting windows? Can you tell me which version should i get? thx
Post by steve » Tue Jul 08, 2014 2:01 pm
ElGoog wrote:so if i install an older version of audacity i can change the volume directly from audacity without affecting windows?
Probably not, but you would be making yourself vulnerable to old bugs that are fixed in Audacity 2.0.5.
ElGoog
Post by ElGoog » Tue Jul 08, 2014 3:17 pm
Thanks for the answers guys. I guess i will have to learn to use the windows mixer then! Cheers
Post by Gale Andrews » Tue Jul 08, 2014 5:36 pm
I'll add your vote for an option to disable hardware linking of the Audacity output slider.
ElGoog
Post by ElGoog » Thu Jul 10, 2014 3:51 pm
Gale Andrews wrote:I'll add your vote for an option to disable hardware linking of the Audacity output slider.
Thats great! Thanks.
