2.0.5 really slow, unresponsive and then crashes
Sami
Re: 2.0.5 really slow, unresponsive and then crashes
Post by Sami » Tue Jul 15, 2014 8:22 am
I exported the file I was working on, then re-opened it as a new project in audacity. It seems to be working ok so far - it doesn't instantly crash but is still rather slow performing simple tasks like cutting.
Post by Gale Andrews » Tue Jul 15, 2014 11:09 am
Sami wrote:I exported the file I was working on, then re-opened it as a new project in audacity. It seems to be working ok so far - it doesn't instantly crash
That is the correct solution for an Audacity project (AUP file and _data folder) that is crashing.
Sami wrote:is still rather slow performing simple tasks like cutting.
Unfortunately Audacity can be slow doing that in long projects, as stated in the Release Notes http://wiki.audacityteam.org/wiki/Relea ... #Interface . If the audio is very long, you can try splitting it up into separate projects.
You haven't said how much disk space you have. Large projects take GB's of data. If you are short of space it takes the computer much longer to find somewhere to put the data.
