Software Lockup
Software Lockup
Version 2.05.0 on win7. The program opens normally but as soon as I open the tab file and then hit open, the program locks up and it locks up badly meaning. ctr/alt/del will not close it nor will any other command except to turn off the computer power.
Re: Software Lockup
As soon as you do... what???as soon as I open the tab file and then hit open,
Open Audacity and Generate > Noise [OK].
Does it make an audio track that looks a little like the attached? If you press play, can you hear hissy or rushing noise?
- Attachments
- Screen Shot 2014-06-30 at 10.25.37 PM.png (102.82 KiB) Viewed 343 times
Re: Software Lockup
The two green circular arrows are the play control. I have an interaction between my screen capture software and Audacity. Koz
- Quality Assurance
Re: Software Lockup
Audacity imports an audio file or opens AUP project files.rocknwray wrote:Version 2.05.0 on win7. The program opens normally but as soon as I open the tab file and then hit open, the program locks up and it locks up badly meaning. ctr/alt/del will not close it nor will any other command except to turn off the computer power.
Audacity can import text files containing Labels using the File > Import > Labels... command.
If the device or drive the file is on is failing or inaccessible (for example a disconnected network drive) this will freeze up Audacity.
If you imported the audio or opened the project and saw blue waves, but the computer crashed when you played the audio, then it is a problem with the audio device you are using. See http://manual.audacityteam.org/o/man/fa ... tml#reboot .
