How can I record using 2 mics?
Re: How can I record using 2 mics?
Post by Gale Andrews » Tue Jul 01, 2014 12:09 pm
Thanks - note we do have a FAQ for this: http://manual.audacityteam.org/o/man/fa ... ml#twomics .
I added Voice Meeter and Alis to the FAQ (the update will appear in the Manual for the next release of Audacity).
vburel wrote:you can record 2 MIC with Voicemeeter (http://www.voicemeeter.com) and Audacity !
see tutorial there for example
http://youtu.be/atobXq-iA-k
Thanks, Vincent.
So Voice Meeter would be a good solution for recording Skype with game audio? We quite often get asked that, but Skype can obstinately cause recording volume fluctuations or dropouts (so we're told).
vburel
Post by vburel » Tue Jul 01, 2014 3:52 pm
Gale Andrews wrote:So Voice Meeter would be a good solution for recording Skype with game audio? We quite often get asked that, but Skype can obstinately cause recording volume fluctuations or dropouts (so we're told).
Yes it can be used for that, by recording Voicemeeter virtual output (called BUS B on the GUI).
- complete documentation available on voicemeeter webpage -
Post by kozikowski » Tue Jul 01, 2014 8:13 pm
That seems to solve a lot of the recording and routing issues — on Windows.
I wonder how they got around the sync issue. You can't resample the microphones without headphone monitoring delay issues and if you don't do something, the two (or more) sources will slowly drift out of time, such as in this post:
http://forum.audacityteam.org/viewtopic ... 46&t=79764
Can we assume those are all USB microphones and headphones? There are little holes in the YouTube where he mentions product numbers.
