beat on recording [SOLVED]
frankly
Post by frankly » Sat Jun 28, 2014 10:29 pm
when recording youtube there is a beat of about 2hz on louder passages. This on xp sp3 Audacity 2.0.2
Re: beat on recording
Post by kozikowski » Sun Jun 29, 2014 12:11 am
That could be feedback. When you record "Stereo Mix," everything on your computer could open up at once including speakers and microphone. Nowhere does it say that feedback has to scream like a bad club band. It can be really low, too like a thump every two seconds.
http://manual.audacityteam.org/o/man/tu ... puter.html
frankly
Re: beat on recording [SOLVED]
Post by frankly » Sun Jun 29, 2014 2:19 am
thanks Koz. Yes it does seem to have been due to audio feedback. The computer I was using is an ASUS Eee with limited freedom to control input and output. I think I solved the problem by disabling software playthrough of sound during recording. Your help is much appreciated.
