WAHWAH CRASH?
WAHWAH CRASH?
Hello everyone, I've been using Audacity for quite some time now (actually only since 2.0.2 as far as I'm concerned) and I've been having trouble with the WahWah effect. When I try to do it, no matter what I do, which track I use it on and how much of the song I choose to WahWah, Audacity crashes. It just crashes. I've searched everywhere for the WahWah crash, asked a lot of people who have Audacity... Just no. I don't get any errors in the program except for WahWah. Nothing else. By the way, I've updated to 2.0.5 today, and hasn't changed. I'm using Windows 7 Home Premium, and I have a 6GB RAM, so little likely to crash because of RAM. Also, it doesn't crash on preview mode, but it crashes even if I select a second of the song.
NEED HELP, PLEASE! T_T
- Quality Assurance
Re: WAHWAH CRASH?
Is it a stereo track or mono? Is the track separated into clips by black vertical lines or white space?
What is the project rate bottom left of Audacity?
What are the exact values of each parameter in Wahwah?
If you right-click over the audacity.exe you launch Audacity with, choose Properties then the "Compatibility" tab, what do you have compatibility set to? Does changing compatibility make any difference?
Re: WAHWAH CRASH?
Hi,Gale Andrews wrote:Is it a stereo track or mono? Is the track separated into clips by black vertical lines or white space?
I'm trying this on stereo tracks.
I've tried both 44 and 48KHz.
The values don't matter, it crashes each time.
I'm not trying it on compatibility mod. I haven't tried changing it, but I don't think it'd make a difference.
- Quality Assurance
Re: WAHWAH CRASH?
There is nothing we can do given Wahwah does not crash for us, unless there is something specific in your tracks that it causing it. In that case we would need you to upload one of the tracks somewhere.
I suggest quitting Audacity and following the steps here: http://manual.audacityteam.org/o/man/fa ... html#reset to reinstall Audacity with the "Reset Preferences" box checked (ticked). When launching Audacity after re-installation, be sure to say "Yes" when Audacity asks you to confirm resetting preferences.
If that does not help, please try changing compatibility mode.
martinaudio
Re: WAHWAH CRASH?
I'm using Windows 7 (español) and Audacity ver.2.0.6
I've experienced this issue whenever I use the wah wah effect Audacity crashes consistently (closes everything without saving the effect).
Similar issues were posted by users native Spanish speakers with over 500 views and 0 replies.
Posted by gaba
Sun Jun 26, 2011 7:04 pm
Forum: Español
Topic: Problema al aplicar el wah wah
Posted by BeN21
Tue Aug 11, 2009 2:08 pm
Forum: Español
Topic: PROBLEMAS CON EL WAH WAH
Posted by JohhnyM
Thu Jan 29, 2009 11:40 pm
Forum: Español
Topic: No puedo aplicar el efecto WahWah
My O.S is also in Spanish, so I tried to change the Audacity language preference to English and then Portuguese (other language than the system default) and it solved this issue
EDIT -> PREFERENCES
Select INTERFACE and changed -> Language:English
Is it possible to solve this bug or error, in order not make this changes of preference and apply the wahwah effect directly using the language-system (in this case is Spanish)?
Cheers, Martin.
Posted by gaba
Forum: Español
Posted by BeN21
Forum: Español
Posted by JohhnyM
Forum: Español
EDIT -> PREFERENCES
Cheers, Martin.
- Quality Assurance
Re: WAHWAH CRASH?
Thanks very much for the report. We didn't know about this - none of the Forum regulars read Spanish so we don't tend to look there.martinaudio wrote:I'm using Windows 7 (español) and Audacity ver.2.0.6
I added a bug report here: http://bugzilla.audacityteam.org/show_bug.cgi?id=861. It doesn't "appear" to be a simple translation problem.
martinaudio
Re: WAHWAH CRASH?
Yes, I believe the OS is crashing Audacity but for a reason which beyond my scope of knowledge.
Whenever this occurs the following message is displayed in a pop-up window:
"Audacity®, the Free, Cross Platform Sound Editor stop working
The program stop functioning properly due to a problem. Windows will end the program and will notify if there is a solution"
I hope that the crew will manage to solve this bug.
Thanks in advance!
Martin.
Thanks in advance!
Martin.
- Quality Assurance
Re: WAHWAH CRASH?
I don't think so - the same happens with Windows in English and Audacity changed to Spanish.martinaudio wrote:I believe the OS is crashing Audacity
Re: WAHWAH CRASH?
I can't test because I'm not on Windows, but I notice that in the Spanish translation there is:
In the second line of the translation:
should be:
Code: Select all
# #: src/effects/Wahwah.cpp:62
#, c-format
msgid ""
"Applied effect: %s frequency = %.1f Hz, start phase = %.0f deg, depth = %.0f"
"%%, resonance = %.1f, frequency offset = %.0f%%"
msgstr ""
"Efecto aplicado: frecuencia %s = %.1f Hz, fase inicial = %.0f grad, "
"profundidad= %.0f% %, resonancia = %.1f, desplazamiento de frecuencia= %.0f%%"
Code: Select all
profundidad= %.0f% %,Code: Select all
profundidad= %.0f%%,9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
- Quality Assurance
Re: WAHWAH CRASH?
That was the problem, thanks for spotting it. I should have looked in a monospace font.steve wrote:I can't test because I'm not on Windows, but I notice that in the Spanish translation there is:
In the second line of the translation:Code: Select all
# #: src/effects/Wahwah.cpp:62 #, c-format msgid "" "Applied effect: %s frequency = %.1f Hz, start phase = %.0f deg, depth = %.0f" "%%, resonance = %.1f, frequency offset = %.0f%%" msgstr "" "Efecto aplicado: frecuencia %s = %.1f Hz, fase inicial = %.0f grad, " "profundidad= %.0f% %, resonancia = %.1f, desplazamiento de frecuencia= %.0f%%"should be:Code: Select all
That change has been committed so the crash should be fixed in the next 2.1.0 release.
