Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Taiziah
Post
by Taiziah » Wed Jun 04, 2014 11:16 pm
I was making a lengthy recording that was at about the 1 hour mark when my computer decided to restart, I was worried the recording had been lost but it appears to have been autosaved, however every time I try to re-open it I receive the error I have included in the title. Any help on how to make this file accessible again would mean so much.
Thank you!
I have attached the file, in case that is of any added help to those who view the thread
- New Project - 2014-06-04 15-13-41 N-5.autosave
- Broken file
- (342.33 KiB) Downloaded 65 times
- Quality Assurance
Post
by Gale Andrews » Wed Jun 04, 2014 11:27 pm
It should just be a question of deleting the redundant line before last which is a series of nulls with a duplicate </project> tag at the end.
I've attached the repaired file.
- (341.99 KiB) Downloaded 48 times
- Quality Assurance
Post
by Gale Andrews » Wed Jun 04, 2014 11:30 pm
Also, if your computer is restarting when recording this strongly suggests a fault with the sound device drivers, or even a hardware fault with the sound device or some other device. See
http://manual.audacityteam.org/o/man/fa ... tml#reboot for what you can do about this problem.
Taiziah
Post
by Taiziah » Wed Jun 04, 2014 11:34 pm
Gale Andrews wrote:It should just be a question of deleting the redundant line before last which is a series of nulls with a duplicate </project> tag at the end.
Thank you so much! I'm honestly really grateful for the speedy reply and everything. Thanks a ton
- Quality Assurance
Post
by Gale Andrews » Wed Jun 04, 2014 11:44 pm
Good. I'll mark this as [SOLVED] and lock the topic.
If recordings continue to cause reboots or you need help updating your audio device drivers, please start a new topic.
- Quality Assurance
Post
by Gale Andrews » Wed Jun 04, 2014 11:52 pm
Gale Andrews wrote:Also, if your computer is restarting when recording this strongly suggests a fault with the sound device drivers, or even a hardware fault with the sound device or some other device.
Or if you were recording unattended, it could be Windows restarting after Windows Update.
It is better to disable updates if you are making important recordings but you can also follow this tip to
stop Windows 7 and Windows 8 forcibly restarting after updates .
