ligaman wrote:i downloaded a selection of songs from youtube and recorded them using audacity.
If you downloaded the videos you could have made it easier by installing
FFmpeg .
Then you could have just dragged the video files into Audacity and it would have extracted the audio for you.
ligaman wrote:i then edited the "project" and added labels before exporting using the export multiple command.the files are saved on the "C" drive and are arranged in alphabetical order.to burn the files i used itunes to create a burn list.does this still mean i did not create an audio cd.
If you want to create an audio CD then the burn settings must be set to "Audio CD" like this:
If you only want to play the CD on your computer it does not matter if it is an audio CD or not.
If you want to play the CD in a boom box/music centre or a car, then you must burn an audio CD.
Note that you can set a gap between the songs in those Burn Settings, so you don't need to make a space between the tracks in Audacity.
But if you have deliberately made long gaps between the songs by dragging each track along the timeline, then when you do Export Multiple, make sure you "Split files based on labels". Don't split based on tracks because your gaps won't be respected - white space before each track will be ignored in the exported file.
ligaman wrote:as regards saving "these" files what i meant was the songs converted to WAV.please let me know if this has made my point any clearer.P S at what point do i use the command to "align tracks"?
You don't need to use it all if you drag the tracks as you intended with space between them. You may want to zoom in to make it easier to see the area between the tracks.
If you don't need any space between the tracks but you want to be sure they do not overlap, then do Edit > Select > All then Tracks > Align Tracks > Align End to End.
