XP Sp3 - Latest 2.0.6-alpha-20-apr-14 - Never start...
DjDiabolik
Hi... i'm new here, i also using more problems like this..... but Audacity it's pretty, faster and........FREE.
I can use the last stable on my PC whit XP Sp3............ i also try to lauch the last naightly version but never started, i can only watch the LOGO apears but never appening, at this point i can only force by TaskManager and kill the process "audacity.exe"
There is a mode to obain a log or similar things for report here ?
- Quality Assurance
Re: XP Sp3 - Latest 2.0.6-alpha-20-apr-14 - Never start...
Thanks for the report.
Have you added VST plug-ins since the problem started? Or added an external audio device?
Have you tried resetting audacity.cfg to
See http://manual.audacityteam.org/o/man/pr ... tml#stored .
Microsoft have made an exception and are offering a patch to XP users for the latest Internet Explorer vulnerability. Make sure you install the patch using Windows Update.
Code: Select all
NewPrefsInitialized=1See http://manual.audacityteam.org/o/man/pr ... tml#stored .
DjDiabolik
No.... it's first time i extract the .zip of latest nightly... and it's never started but the last stable working whitout problems.
Late Tonight i turn on my pc with XP and i can try to add this value on CFG... i report result here.
Thanks for support.
Thanks for support.
- Quality Assurance
If the alpha build still won't start on an initialised audacity.cfg, then without changing any audio devices, launch 2.0.5 release and post the information from Help > Show Log... and Help > Audio Device Info... .
Thanks,
Thanks,
DjDiabolik
Ok... i'm goin to watch the .cfg.
In the first line it's present this:
For resetting this i need to set NewPrefs to 0 ??
Otherwise i have a similar EXTERNAL AUDIO CARDS... i have installed on pc a BEHRINGER BCD3000 whit asio support....... it's not a real external audio cards but it's support the DIRECT AUDIO.
Try to Starts the latest stable and post here the log you suggested....
Code: Select all
Version=2.0.5
PrefsVersion=1.1.1r1
DjDiabolik
It's the LOG of 2.0.5 latest stable:
And this is the Audio information log:
Code: Select all
16:25:17: Audacity 2.0.5
16.25.18: Trying to load FFmpeg libraries...
16.25.18: mLibAVFormatPath ('D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windowsavformat-52.dll') is not empty. Loading from it.
16.25.18: Looking up PATH environment variable...
16.25.18: PATH = 'C:GTKbin;C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;C:WINDOWSsystem32WindowsPowerShellv1.0;C:ProgrammiUniversal Extractor;C:ProgrammiUniversal Extractorbin;D:Programmimkvtoolnix2.6.0;C:ProgrammiATI TechnologiesATI.ACECore-Static;C:ProgrammiOpenVPNbin'
16.25.18: Checking that 'D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windows' is in PATH...
16.25.18: Avviso:FFmpeg directory is not in PATH.
16.25.18: Temporarily appending ';D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windows' to PATH...
16.25.18: Checking for monolithic avformat from 'D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windowsavformat-52.dll'.
16.25.19: Errore: Impossibile trovare il simbolo 'avutil_version' nella libreria dinamica (errore 127: impossibile trovare la procedura specificata.)
16.25.19: avformat not monolithic
16.25.19: Loading avutil from 'D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windowsavutil-50.dll'.
16.25.19: Loading avcodec from 'D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windowsavcodec-52.dll'.
16.25.19: Loading avformat from 'D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windowsavformat-52.dll'.
16.25.19: Returning PATH to previous setting...
16.25.19: Actual avutil path D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windowsavutil-50.dll
16.25.19: Actual avcodec path D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windowsavcodec-52.dll
16.25.19: Actual avformat path D:ProgrammiFFmpeg_v0.6.2_for_Audacity_on_Windowsavformat-52.dll
16.25.19: Importing symbols...
16.25.19: All symbols loaded successfully. Initializing the library.
16.25.19: Retrieving FFmpeg library version numbers:
16.25.19: AVCodec version 0x344802 - 52.72.2 (built against 0x344802 - 52.72.2)
16.25.19: AVFormat version 0x344002 - 52.64.2 (built against 0x344002 - 52.64.2)
16.25.19: AVUtil version 0x320f01 - 50.15.1 (built against 0x320f01 - 50.15.1)
16.25.19: FFmpeg libraries loaded successfully.Code: Select all
Default capture device number: 1
Default playback device number: 4
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0,090000
Low Output Latency: 0,090000
High Input Latency: 0,180000
High Output Latency: 0,180000
Supported Rates:
Device ID: 1
Device name: SoundMAX Digital Audio
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 2
Device name: BCD3000
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 3
Device name: Microsoft Sound Mapper - Output
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 4
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 5
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 6
Device name: Driver primario di acquisizione suoni
Host name: Windows DirectSound
Input channels: 2
Output channels: 0
Low Input Latency: 0,120000
Low Output Latency: 0,000000
High Input Latency: 0,240000
High Output Latency: 0,000000
Supported Rates:
Device ID: 7
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 8
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 9
Device name: Driver audio principale
Input channels: 0
Output channels: 2
Low Input Latency: 0,000000
Low Output Latency: 0,120000
High Input Latency: 0,000000
High Output Latency: 0,240000
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 10
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 11
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Selected capture device: 7 - SoundMAX Digital Audio
Selected playback device: 10 - BCD3000
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Available mixers:
Available capture sources:
0 - Lettore CD
1 - Microfono
2 - Aux
3 - Linea in ingresso
4 - Telefono
5 - Uscita mono
6 - Mix wave in uscita
Available playback volumes:
0 - Wave
1 - Sintetizzatore SW
2 - Lettore CD
Capture volume is native
Playback volume is native
No. To reset the Audacity preferences you need to delete the entire contents of the audacity.cfg file except for the one line:DjDiabolik wrote:Ok... i'm goin to watch the .cfg.
In the first line it's present this:For resetting this i need to set NewPrefs to 0 ??Code: Select all
NewPrefsInitialized=1 Version=2.0.5 PrefsVersion=1.1.1r1
Code: Select all
NewPrefsInitialized=19/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
DjDiabolik
ok...... i try to reset this file........... and retry to restart the latest beta:
After double-click on .exe i obtain the message to association of file....... i click ok...... and after that nothig append, i continue to see the logo "Audacity" over my desktop but the main programs never appears
DjDiabolik
Nothing..... after this failed started i come to see if the mail .cfg has been modified..... now contain this:
For now i reset and using the last stable...........
Code: Select all
Version=2.0.6-alpha-Apr 20 2014
WantAssociateFiles=1
[Version]
Major=2
Minor=0
Micro=6
[Directories]
TempDir=C:\DOCUME~1\utente\IMPOST~1\Temp\audacity_temp
DjDiabolik
This is the .cfg after a clear start of latest stable:
I have only modify some value like add the lame and ffmpeg path.......
Code: Select all
Version=2.0.5
SnapTo=0
SelectionFormat=hh:mm:ss + millisecondi
[Version]
Major=2
Minor=0
Micro=5
[Directories]
[AudioIO]
RecordingDevice=SoundMAX Digital Audio
Host=MME
PlaybackDevice=BCD3000
RecordingSourceIndex=1
RecordingSource=Microfono
RecordChannels=2
EffectsPreviewLen=6
CutPreviewBeforeLen=2
CutPreviewAfterLen=1
SeekShortPeriod=1
SeekLongPeriod=15
Duplex=1
SWPlaythrough=0
LatencyDuration=100
LatencyCorrection=-130
SoundActivatedRecord=0
SilenceLevel=-50
[VST]
Rescan=0
Enable=1
GUI=1
[FFmpeg]
Enabled=1
FFmpegLibPath=D:\Programmi\FFmpeg_v0.6.2_for_Audacity_on_Windows\avformat-52.dll
[GUI]
ShowSplashScreen=0
ErgonomicTransportButtons=1
EnvdBRange=60
Help=Local
BeepOnCompletion=0
ShowTrackNameInWaveform=0
RetainLabels=0
AutoScroll=1
TracksFitVerticallyZoomed=0
DefaultViewMode=0
SelectAllOnNone=1
EnableCutLines=0
AdjustSelectionEdges=1
CircularTrackNavigation=0
EditClipCanMove=1
Solo=Standard
EmptyCanBeDirty=1
[GUI/ToolBars]
[GUI/ToolBars/Control]
Dock=1
Order=1
Show=1
X=-1
Y=-1
W=327
H=55
[GUI/ToolBars/Tools]
Dock=1
Order=2
Show=1
X=-1
Y=-1
W=94
H=55
[GUI/ToolBars/Meter]
Dock=1
Order=3
Show=1
X=-1
Y=-1
W=338
H=55
[GUI/ToolBars/Mixer]
Dock=1
Order=4
Show=1
X=-1
Y=-1
W=323
H=27
[GUI/ToolBars/Edit]
Dock=1
Order=5
Show=1
X=-1
Y=-1
W=377
H=27
[GUI/ToolBars/Transcription]
Dock=1
Order=6
Show=1
X=-1
Y=-1
W=140
H=27
[GUI/ToolBars/Selection]
Dock=2
Order=1
Show=1
X=-1
Y=-1
W=717
H=55
[GUI/ToolBars/Device]
Dock=1
Order=7
Show=1
X=-1
Y=-1
W=620
H=27
[MP3]
MP3LibPath=D:\Programmi\Lame for Audacity\lame_enc.dll
[SamplingRate]
DefaultProjectSampleRate=48000
DefaultProjectSampleFormat=262159
[Quality]
LibsoxrSampleRateConverter=1
DitherAlgorithm=0
LibsoxrHQSampleRateConverter=3
HQDitherAlgorithm=3
[Locale]
Language=
[FileFormats]
CopyOrEditUncompressedData=copy
ExportDownMix=1
AllegroStyle=1
SaveProjectWithDependencies=ask
[AudioFiles]
NormalizeOnLoad=0
ShowId3Dialog=1
[ExtendedImport]
OverrideExtendedImportByOpenFileDialogChoice=1
[Spectrum]
FFTSize=256
WindowType=3
MinFreq=0
MaxFreq=8000
Gain=20
Range=80
FrequencyGain=0
Grayscale=0
[Warnings]
FirstProjectSave=1
DiskSpaceWarning=1
MixStereo=1
MixMono=1
CopyOrEditUncompressedDataAsk=1
[Ladspa]
Enable=1
[Nyquist]
Enable=1
[VAMP]
Enable=1
[Prefs]
PrefsCategory=9
[Window]
X=-4
Y=-4
Width=1032
Height=742
Maximized=1
Normal_X=0
Normal_Y=0
Normal_Width=780
Normal_Height=620
Iconized=0
