Hi, just bought this, hooked it up and Vista seems to have installed all the drivers as it works with my mic but Audacity doesn't see it .
Any ideas?
Thanks
Dwayne
USB Dual Pre
Re: USB Dual Pre
Restart Audacity or Transport > Rescan. Audacity checks for new devices when it starts.
