Please be aware of
Windows XP support has ended - Microsoft Windows . This makes it very important you disconnect the internet before turning off your virus checker.
Did you ever launch Audacity with Avast! totally switched off? Avast! is a possible cause but it may have multiple processes that you must ensure are not running.
I am not sure if you ever see the
Install VST Effects Dialogue when you launch Audacity but I suggest making sure Audacity is quit in Task Manager, then open
Code: Select all
C:Documents and Settings<your user name>Application DataAudacity
If you don't see the Application Data folder, follow the steps at
http://www.bleepingcomputer.com/tutoria ... ows/#winxp to show hidden files and folders. In the "Audacity" folder inside Application Data, delete the file "audacity.cfg" if it exists, then paste in the attached file renamed to "audacity.cfg" (without quotes). This will reset preferences but also disable Audacity scanning for VST effects.
If that does not help, what language do you have "Format" set to in "Region and Language" in the Windows Control Panel?
Assuming your reference to "SB" means Creative SoundBlaster, that could be the problem. If it's a USB SoundBlaster, disconnect it and see if Audacity launches. If the SoundBlaster is installed into the PCI slot, or if you remove the USB SoundBlaster and Audacity still doesn't launch, try
starting the computer in safe mode . This will mean only essential Windows drivers will load. You won't have any sound devices, but it tells us the problem is not Windows.
