Music In My Recording
adamlobb
Post by adamlobb » Wed Apr 09, 2014 10:16 pm
hi there, i need some help, now when i record, i hear the music (as if it's an instrumental) in my recording, i know what you're thinking, yeah he has his headphones too loud but no, this only happens on a certain laptop i use, and in 2 different microphones. i've updated the driver but no luck, i will give you a sample of what i mean..
basically it's like when you use stereo mix to record stuff playing off of your system, but in my recordings
http://www.sendspace.com/file/0i75gf
thanks for anyones help
Re: Music In My Recording
Post by steve » Thu Apr 10, 2014 1:48 pm
You will need to describe your setup in detail.
Where is that music playing?
What equipment are you using and how is it all connected?
What settings in Audacity?
What settings in the Windows Sound Control Panel?
