Can't open Audacity
Can't open Audacity
Im running window 7 64 bit and when i try to open Audacity it pulls up an error that says "the application was unable to start because its side-by-side configuration is incorrect" how can i fix this?
Reason: Fixed typo in topic title
- Quality Assurance
Re: Can't open Audacity
Which version of Audacity? See the pink panel at the top of this page.Gom235 wrote:Im running window 7 64 bit and when i try to open Audacity it pulls up an error that says "the application was unable to start because its side-by-side configuration is incorrect" how can i fix this?
If you don't already have 2.0.5, please download it here:
http://audacityteam.org/download/windows .
If the problem persists in 2.0.5, please try installing the Microsoft Visual C++ 2008 SP1 Redistributable Package (x64) from http://www.microsoft.com/en-us/download ... px?id=2092 .
