recording start up
bbdist
recording start up
Post by bbdist » Fri Mar 07, 2014 8:43 pm
As soon as I try to start a recording I get a very High pitch sound that I can't stop. some times I even have to close it to stop the niose ????
Re: recordig start up
Post by kozikowski » Fri Mar 07, 2014 10:12 pm
Are you on headphones? You can't live record with speakers running. Are you trying to self-record — are you trying to record YouTube or something on-line? Make sure your sound pathways are set up right. Self Recording establishes reverse sound pathways and if you do it wrong, it's a howling feedback path.
http://manual.audacityteam.org/o/man/tu ... puter.html
Re: recording start up
Post by Gale Andrews » Sat Mar 08, 2014 7:22 pm
If you have a USB turntable, see this: http://wiki.audacityteam.org/wiki/USB_t ... hite_Noise .
Tell us exactly what you are recording and how if you need more help. Tell us what version of Windows and what version of Audacity (see the pink panel at the top of this page).
bbdist
Post by bbdist » Sun Mar 09, 2014 1:19 pm
thanks ! Got it .
