using windows 8 aud 2.0.5. used exe to dl
works fine but tried to record something from a cassette and ran into trouble.samsung laptop has 1 headphone/microphone jack.I read somewhere to split it using a combo jack.bought that but no sound comes through to the recording.sorry I couldn't find this in prev forums.thanks for any ideas
record audacity using headphonemicrophone jack
Re: record audacity using headphonemicrophone jack
As a general rule, entertainment/stereo recording needs to be done outside the computer. I use a Behringer UCA202 with a Windows PC...
http://www.kozco.com/tech/audacity/pix/ ... Lenovo.jpg
It also works on Mac and Linux. If you need to direct-connect a conventional turntable, Behringer also makes the UFO202 with a built-in phono preamplifier and ground connection.
Other people make devices like this.
Be careful about devices like the Startech ICUSBAUDIO which will not accept a stereo connection any more than your PC does.
Scroll down to USB Devices.
http://wiki.audacityteam.org/wiki/Recom ... nd_devices
thanks for that quick response
