chopping audio into equal length
046oh
Post by 046oh » Tue Feb 25, 2014 10:34 am
windows
2.0.5
exe
can i do the following:
define length
chop selected region into chunks of the specified length
i want to use this to make loops
thanks
waxcylinder
Re: chopping audio into equal length
Post by waxcylinder » Tue Feb 25, 2014 1:31 pm
Yes you can - see this page in the manual: http://manual.audacityteam.org/o/man/re ... abels.html
