Move selection without changing the length
046oh
Post by 046oh » Mon Feb 24, 2014 3:37 pm
windows 7
2.0.5
exe
is it possible to shift a selection, keeping the length the same?
i want to use it to find good loops from a song
Reason: Clearer topic title
Re: some maneuver questions
Post by kozikowski » Mon Feb 24, 2014 6:00 pm
Theory has it you can use the time entry windows at the bottom of the window. Select Start for the first one and Length for the second.
Post by Gale Andrews » Mon Feb 24, 2014 8:17 pm
Would you like to request a way to do that by dragging the selection with the mouse?
