how to reset vertical scale
046oh
Post by 046oh » Mon Feb 24, 2014 3:14 pm
i know i can do "zoom normal" to reset the horizontal magnification, but i can't reset my vertical scale.
how do i do this?
Windows 7
Audacity 2.0.5
I think i used the exe
Re: how to reset vertical scale
Post by kozikowski » Mon Feb 24, 2014 3:43 pm
Hold the Shift key and click in the vertical indicator bar to the left of the track. Just Clicking alone magnifies.
Post by steve » Mon Feb 24, 2014 4:06 pm
Or right click on the vertical scale.
Post by Gale Andrews » Mon Dec 07, 2015 9:39 am
Or SHIFT + right-click to reset the range of the vertical scale to 0 Hz to the maximum for the sample rate (so 0 to 22050 Hz for 44100 Hz rate).
