How can you edit stereo channels independently
PappyLove
Post by PappyLove » Sun Feb 23, 2014 7:00 pm
I do not find a way to edit stereo channels independently. I need to remove parts of one channel without affecting the other channel. Is it possible and if so how?
Thanks for any suggestions.
Re: How can you edit stereo channels independently
Post by steve » Sun Feb 23, 2014 7:46 pm
Split the stereo track, do the edit, then rejoin back into a stereo track.
See here for more details: http://manual.audacityteam.org/o/man/sp ... racks.html
