Audacity Won't open Aup. Project
So i was working on a project an started having internet troubles so saved i my project as a aup. and rebooted my computer. When i tried to load my file it says it doesn't recognize the type of file. I see the data folder with all the files so i take it its still there. The only thing i recall doing is moving my project file in a separate folder away from the data folder. Now i have them both in a new folder by them self and it still won't open. Any ideas? help would be appreciated i'd hate to start over.
Re: Audacity Won't open Aup. Project
What's the chances of putting them both back in exactly the folder they left?
- Quality Assurance
You must never do that.zts24 wrote:So i was working on a project an started having internet troubles so saved i my project as a aup. and rebooted my computer. When i tried to load my file it says it doesn't recognize the type of file. I see the data folder with all the files so i take it its still there. The only thing i recall doing is moving my project file in a separate folder away from the data folder.
AUP and _data folder must be in the same folder.zts24 wrote:Now i have them both in a new folder by them self and it still won't open.
The AUP must not be in the _data folder, but must be alongside the _data folder when you look in Windows Explorer.
Open the AUP file from File > Recent Files, or using File > Open... . Don't use File > Import > Audio... .
Attach the AUP file if you are still stuck after that. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936 .
- Quality Assurance
That would solve it too, but they don't need to be together in their original folder. They can be together in any folder.kozikowski wrote:What's the chances of putting them both back in exactly the folder they left?
