I'm in Windows 7, Audacity 2.0.1
I'm sure I just accidentally toggled something, but i can't figure out what it was. and i can't undo it.
Somehow, i just made it so when I click and drag (using mouse, touchpad, etc), it automatically selects in one second increments. I can't even change the boundaries to be less or more. It's one second, two seconds, etc. or nothing.
Please help - this is driving me insane.
problem with selecting
juliehoverson
Re: problem with selecting
Snap-To on the bottom of the window.
