does'nt recognize vibe turntable
tincup138
Post by tincup138 » Sat Feb 15, 2014 11:34 pm
using windows 8.1 audacity 2.0.5 exe installer
ERROR WHILE OPENING SOUND DEVICE. PLEASE CHECK THE INPUT DEVICE SETTINGS AND THE PROJECT SAMPLE RATE."
My pulldown does not have any of the device settings on the mike pulldown it has= Disable Meter- Horizontal Stereo-
Vertical Stereo= Linar Db- Peferences not like the sample shown I can change the sample rate
Re: does'nt recognize vibe turntable
Post by kozikowski » Sun Feb 16, 2014 2:27 am
Audacity > Edit > Preferences > Devices > Recording > Turntable, Stereo.
Audacity > Edit > Preferences > Quality: 44100, 16-bit.
Try resetting your Audacity like that. The "Turntable" name is whatever your turntable looks like to Audacity. I have a device that looks like "USB Audio Codec". It could be named anything.
http://manual.audacityteam.org/o/man/fa ... und_device
tincup138
Post by tincup138 » Sun Feb 16, 2014 12:38 pm
The problem is that audacity does'nt see the turntable
Post by Gale Andrews » Sun Feb 16, 2014 3:15 pm
Make sure the computer sees the turntable. Follow all the steps at "Detecting USB and Firewire Devices" in the green box here: http://manual.audacityteam.org/o/man/fa ... l#flatline .
For setting up Audacity once it sees the turntable, please read Recording with USB turntables or USB cassette decks - Audacity Manual .
