Best way to get peak amplitude?
pdun459
Post by pdun459 » Sat Feb 08, 2014 11:03 pm
I found this script that runs from the Nyquist Prompt and it works very good, but apparently it has to be re-entered if you close Audacity. I was wondering if there's any other way to get the peak amplitude that doesn't require the re-enrty of a script, or if there's a way to save this script in Audacity so I can just select it from the interface? Many thanks. :)
Re: Best way to get peak amplitude?
Post by Gale Andrews » Sun Feb 09, 2014 2:45 pm
If you need more than the one decimal place accuracy of looking in Effect > Amplify, there is now a plug-in for that script. See http://forum.audacityteam.org/viewtopic ... 42&t=75677 .
There is no way to store or reload scripts across sessions using Nyquist Prompt. Do you want to vote for that?
Perhaps Nyquist Workbench (not yet released) can do that? Steve would know.
pdun459
Post by pdun459 » Sun Feb 09, 2014 5:06 pm
Sweet, thank you. :)
Post by steve » Sun Feb 09, 2014 5:20 pm
Gale Andrews wrote:There is no way to store or reload scripts across sessions using Nyquist Prompt. Do you want to vote for that?
Nyquist Workbench can save and load scripts. It can even automatically open the script that was last used (provided that the script was saved as a file).
