Earlier this week I download Audacity to enable me to record my old vinyl so I can transfer the music to my iPod. Everything appears to have run smoothly until I attempt to record then I get a 'ghastly noise' that almost drowns out what I'm recording - this noise occurs both during the recording process and playback. I'm using a USB Turntable D6027 - hopefully, one of you lovely people can advise as to what I've done wrong or if it's an issue with my turntable. Please bear in mind that, although I'm not a total Luddite, I am a middle aged woman who is a little technically challenged so, be gentle with me! Thanks xxx
Ghastly noise
SaffythistleUK
Ghastly noise
Hi
Re: Ghastly noise
Try rebooting your computer.
Try using a different USB port.
Don't use a USB hub - the turntable must be plugged directly into the computer.
Avoid running other programs at the same time.
- Quality Assurance
Re: Ghastly noise
Also, try another USB cable and make sure the headshell on the cartridge is tight (if it's removable).
