I was using Audacity 2.0.5 to mix two audio bits together for a guitar cover I was making. The first half (Of both tracks) sounded alright, but the second half? Not at all. That's where I need help.
If you could help me in any way, or possibly even mix the audio themselves, please reply or contact me at <email address removed>
Both files are here: http://www.mediafire.com/view/a7tt9l06e ... -Train.aup
Thank you for your time.
Note: It starts getting bad at around 2:50
Moderator note: I removed your email address for you to protect you from SPAMbots harvesting your address. Plus we prefer to keep all discussions on this open forum so that all readers can benefit. Thanks.
AUDIO TROUBLES
Re: AUDIO TROUBLES
AUP is not a sound file. It's a text file that manages Audacity projects. Post a very high quality MP3 (250 stereo or higher) or a WAV file.
Re: AUDIO TROUBLES
I'm sorry, could you simplify that for me? It's a bit of an understatement when I call myself a "newbie."kozikowski wrote:AUP is not a sound file. It's a text file that manages Audacity projects. Post a very high quality MP3 (250 stereo or higher) or a WAV file.
- Quality Assurance
Re: AUDIO TROUBLES
Open the AUP file in Windows Media Player. Do you hear audio? No, so it is not an audio file. Please attach one - see http://forum.audacityteam.org/viewtopic ... 49&t=72887 for how to do that.Anthony O wrote:I'm sorry, could you simplify that for me? It's a bit of an understatement when I call myself a "newbie."kozikowski wrote:AUP is not a sound file. It's a text file that manages Audacity projects. Post a very high quality MP3 (250 stereo or higher) or a WAV file.
