What do you mean by "add a track"? If you want to make a 7.1 file instead of 5.1, add the tracks in Audacity.MIMMO61 wrote:But how do I add a track to pcm multichannel larger than 4 GB?
Have you tried to see if the file is under 2 GB if exported as FLAC?
If you must make a PCM file larger than 4 GB you must use RF64, because the WAV specification does not allow more than 4 GB. RF64 is lossless PCM, but it should not use WAV extension, so it has RF64 extension instead. See my post for how to export as RF64.
