Need Help Fixing Clipping
Hi,
I have recorded over 90 min of material. Unfortunately, I have a fair amount of intermittent momentary clipping throughout.
I'm quite new at recording and I couldn't figure out what was going on during the session. Levels seem good except at intermittent moments when they would jump significantly without pattern or warning.
I was using an Audio Technica Pro 70 lavalier and a Tascam DR-D60 field recorder to record a woman's speaking voice.
After viewing the audio and video tracks I think it had to do with the talent's vocalizing techniques especially her plosives.
Now, I need to figure out how to repair. Can anyone offer any advice? Are there any tools or workflows in Audacity or even elsewhere that might be helpful? I'm not that familiar with the program but I did look it over and, so far, nothing jumped out at me.
Would appreciate any suggestions.
thanks
thanks
Re: Need Help Fixing Clipping
There's Effects > Clip Fix. What it tries to do is "paper over" the worst of the damage. You can't actually fix clipping because that's a portion of the recording where there is no recording. It's like somebody took a small hand gun and fired it at the blue waves.
The question is can you hear the clip points? Listen on good headphones.
If you mount a lavalier too far down it will catch the actor's breaths in addition to the voice. That will give you enormous peaks in the wave, but you may not be able to hear them. The microphone is intended to go just inside the acoustic shadow of the chin.
http://kozco.com/tech/audacity/pix/lavalier2.jpg
Try this. Drag-select a portion of the show with a lot of damaged peaks and Effect > High Pass Filter: 100Hz, 24dB.
Do they all suddenly go away? Then the breath thing is likely what happened. Many of us use the mixer 100Hz filter on voices to prevent that. That and put the lavalier in the right place. Do a world of good.
Koz,
Thanks for your reply! I thought I responded the other night but I don't see it here.
I think you touched on my problem. I definitely placed the lavalier lower on the chest than your picture would indicate. My placement was rather consistent with Audio-Technica instructions but my troubled results support your analysis.
I have applied the high pass settings that you advise. They helped significantly in many place but never totally, always leaving some sort of softer click type noise behind. I have one place, so far, that must have been more severely clipped because I'm have trouble repairing it.
Wonder if you have any suggestions for the remaining post "high-pass" click type sounds or the more powerful clipping area.
I am so grateful for your help. As it turns out, very little of the distortion was due to actual clipping. Most due to air hitting the mic. Though not a perfect fix, the "high pass" has allowed me to salvage most of my footage.
BillyB
BillyB
- Quality Assurance
So did you try Clip Fix for the more damaged area?BillyB wrote:I have applied the high pass settings that you advise. They helped significantly in many place but never totally, always leaving some sort of softer click type noise behind. I have one place, so far, that must have been more severely clipped because I'm have trouble repairing it.
You can also zoom in to almost where you can see the individual audio samples and try Effect > Repair .
Does the clipping sound like "esses"? If so you could try Lisp . It's a VST plug-in. Please see here for how to install VST Plug-ins: http://manual.audacityteam.org/o/man/fa ... st_install .
Hi Gale,
I expected to see "lisp" in my list of "Effect" drop down list in Audacity but I don't see it there. Neither to I see anything like "De-Esser".
Am I looking in the wrong place? Did I do something wrong?
Please help!
thanks
Yes, I did. It didn't seem to have much effect. I did get it to round out the top of one of my distorted wave forms but there is still problems with it.Gale Andrews wrote:So did you try Clip Fix for the more damaged area?
I tried repair but also wasn't successful. Perhaps, I need to work with it some more.Gale Andrews wrote:You can also zoom in to almost where you can see the individual audio samples and try Effect > Repair .
The clipping doesn't sound like esses in this particular clip. The problem is with "T"s in this particular clip. I read on the "Lisp" home page that it also works with "teh" sounds. Perhaps, that would help me. I tried to install it but I'm having problems. Please help. Here is what I did:BillyB wrote:Does the clipping sound like "esses"? If so you could try Lisp . It's a VST plug-in. Please see here for how to install VST Plug-ins: http://manual.audacityteam.org/o/man/fa ... st_install .
- I downloaded the .zip file.
I copied the lisp.dll file from the .zip/vst2/x86 folder to the audacity plugins folder.
I edited Audacity preferences to rescan .vst files upon opening and restarted Audacity.
Please help!
thanks
Upon further inspection, I did find at least one distorted "s" problem with sibilance which leaves me even more interested in getting "lisp" working.
Looking forward to hearing from you on the install problem.
Robert J. H.
It may be necessary to scan the whole effect list. External plug-ins have sometimes "VST" or the manufacturers name in front of it.
Here is the install screen that presents when restarting Audacity. Note that Lisp is first on the list.
I simply click "ok" or press enter and Audacity ticks through each item on the list. I interpret this to be installing behaviour but could be wrong. (I've since done this multiple times - hope that wasn't a problem.)
Please help me figure out why this isn't working for me.
- [1] Am I choosing the correct .dll file? VST2/x86/lisp.dll
[2} Does my install window and process seem correct?
[3] Why am I presented with the same long list of plugins to install each time? Is this normal or is this an indication that they are not installing?
[4] If installing each time, is there a problem with multiple installations or does the install just put the same files in the same places?
[5] Am I looking for the plugin in the right place in Audacity? i.e. The "Effects" drop down list.
[6] What name does it go by within Audacity? Is it called "Lisp". (I have a ton of Effects in the drop down. I've looked through them many times but I could be missing it if it is called something else.)
Robert J. H.
Search under effects for Sleepy-Time DSP: Lisp...
Got it Robert, thanks! Man, sometimes it's the simple things. I can stop beating my head against the wall.
