GSnap question
superfresh480
GSnap question
Okay i downloaded gsnap you know the auto tune plugin. When i apply it to the song it auto tune the whole thing not just my voice the beat to which messed up the whole song. I want to know how to auto tune just my voice with gsnap.
- Quality Assurance
Re: GSnap question
GSnap does not fully work with Audacity because Audacity does not have MIDI input support.superfresh480 wrote:Okay i downloaded gsnap you know the auto tune plugin. When i apply it to the song it auto tune the whole thing not just my voice the beat to which messed up the whole song. I want to know how to auto tune just my voice with gsnap.
If you have the voice on a separate track you can apply the GSnap effect to just that track by clicking above the Mute / Solo buttons of the voice track to select only the voice track.
From the GSnap Manual: http://www.gvst.co.uk/gsnap_manual.htm
If you have a stereo voice track, use Tracks > Stereo Track to Mono.It requires a monophonic input signal to operate.
If you only have a stereo track with the voice and the beat mixed together, you can try isolating the voice, but this does not work on all tracks. See http://manual.audacityteam.org/o/man/tu ... ation.html .
Audacity does not make GSnap, so we cannot help you how to use it.
There are some YouTube tutorials here you may want to look at, depending what you want to do:
http://www.youtube.com/watch?v=CvIwA89mfIE
http://www.youtube.com/watch?v=-A_a0Zxs ... r_embedded .
You can also try AutoTalent instead of GSnap:
http://www.vst4free.com/free_vst.php?pl ... ent&id=842 .
AutoTalent also expects a mono voice (or instrument) track to work on.
If you buy AutoTune or Melodyne they will give you technical support.
