Audio pattern
stardust2003
Audio pattern
Post by stardust2003 » Thu Dec 05, 2013 8:11 pm
Hi,
Ive been recording using audacity.... tape in music centre
mic near the speaker ... and been getting good results.
Suddenly the sound pattern has changed to this
and Im losing the quality of sound.
the clips I do are mainly speech, I can still get the audio but it is not as sharp and clear as usual
I think you ll agree, the wave pattern above is not right
Re: Audio pattern
Post by steve » Thu Dec 05, 2013 8:52 pm
Wow that's impressive.
My first guess is that your sound card has just gone belly up.
Nothing changed as far as you're aware that could relate to the problem?
stardust2003
Re: Audio pattern
Post by stardust2003 » Thu Dec 05, 2013 10:28 pm
funny, Im not seeing that pic of audacity I posted ....
Just played an audio file and it was ok so the sound card has nt gone
think Ive seen this kind of pattern before but so long ago Ive forgotten about it.
Strange Ive made about 25 audio recordings during the last week with the mic about
12 inches from the music centre speaker and they ve all been great.
Now suddenly this... spose Ill have to start trying a few things... like changeing the mic !
Re: Audio pattern
Post by steve » Fri Dec 06, 2013 1:03 am
stardust2003 wrote:funny, Im not seeing that pic of audacity I posted ....
Neither am I now.
I seems that the imageshack file has gone offline.
stardust2003 wrote:Just played an audio file and it was ok so the sound card has nt gone
There's 2 sides to a sound card, input and output.
It may be worth checking to see if Windows has updated your sound card drivers. If it has, you may be able to "roll back" the drivers to the previous version.
Sorry I've not got a definitive solution to the problem.
stardust2003
Re: Audio pattern
Post by stardust2003 » Fri Dec 06, 2013 2:06 am
LETS TRY AGAIN
you ve got to admit, that sound wave is a bit abnormal.
However Ive had another go at recording the audio... about elvis meeting the beatles...
and it still looked a bit wierd on audacity, but it does nt sound too bad on the playback .
Re: Audio pattern
Post by steve » Fri Dec 06, 2013 2:28 am
I think it is highly unlikely, but to cover all bases, just in case Audacity is screwing up on the graphic rendering, could you post a short audio sample in WAV format and I'll check it here. See here for how to post an audio sample: http://forum.audacityteam.org/viewtopic ... 49&t=72887
stardust2003
Re: Audio pattern
Post by stardust2003 » Fri Dec 06, 2013 10:37 pm
The audio pattern seems to have calmed down a bit now, and the audio recording
does nt seem too bad
just recorded this
go here
https://archive.org/details/LESLIETHOMASISLANDCHATTTT
If you go to the right hand side, you should be able to listen on line.
I was recording by wire out of the earphone socket of my pioneer music centre
but had a few probs so now Ive got a microphone plugged into my comp and the mic
about 12 inches from my pioneer speaker.
I DARE say Im stuck with mono forever now, but thats ok !
Re: Audio pattern
Post by steve » Sat Dec 07, 2013 5:23 pm
stardust2003 wrote:The audio pattern seems to have calmed down a bit now, and the audio recording
There is clearly still a fault:
stardust2003
Re: Audio pattern
Post by stardust2003 » Sun Dec 08, 2013 4:47 pm
JUST BEEN to preferences and moved the sample rate up to 16000
and the bit rate up to 24 bit
