Record On My Laptop Not Working
Audacity02
Hello,
I am wondering if someone could provide me with some basic standard setup options that I can enter into the Preferences section of Audacity. My attempt to record is resulting in a very low-volume sound that is mostly sputtering --- kind of garbaggy. On the Playback there is almost no recognition of the music I try to record. I am basically a novice when it comes to knowing what a reasonable 'setup' should be in music terms, so please forgive me if my questions seem a bit dumb. I did try to read the Help area and make some changes in Preferences, but now I am feeling confused.
My version of Audacity is 2.0.5, and I am using Vista Home edition of Windows. It is possible that my laptop is the problem (I think), but I am not sure. I hope I can still make some decent simple recordings.
Thanks to all,
Joe
Thanks to all,
Joe
Re: Record On My Laptop Not Working
Hi Joe. What are you trying to record, for example: "I'm trying to record from an Ion USB turntable, model "Profile LP" which is connected via a USB hub to my laptop".
(by the way, recording via a shared USB hub is not recommended).
Perhaps you could post a short audio sample to demonstrate the problem. Just a couple of seconds in WAV format will help. (instruction here: http://forum.audacityteam.org/viewtopic ... 49&t=72887)
Audacity02
Hi Steve,
First of all thank you very much for the fast reply.
(1) I am trying a simple 'record' of a song I found on the Grooveshark music website. I start up Audacity, press 'Record', and play the song (Don Henley's "Sunset Grill"). As a test, I let the song run for about 30 secs - 1 min, and then press 'Stop' in Audacity. I then 'Play' in Audacity, which is where I get the bad result.
(2) I will be happy to provide a sample of my result for you. I assume I save the file in Audacity in 'WAV' format, is that correct? After I save it, how do I provide it to you? Do I attach it here as part of my next reply to you?
Again, many thanks Steve.
Joe
Joe
This page tells you how to record streaming audio.
Streaming audio is generally more compressed (lower bitrate & lower quality) than downloads from Amazon or iTunes, but when you record it, the recording shouldn't sound much worse than when you listen to it in real-time.
Audacity02
DVDDoug,
Thanks for the comments. I will read the info shown in the link you provided. And I feel encouraged by the thought that a recording I make shouldn't sound too bad in the end.
Steve,
I saved the sample I recorded into a WAV format file. Should I attach it in this area? Do I use the Upload attachment tab?
Thanks to both of you.
Joe
Steve,
Joe
Yes, upload it here. Instructions here: http://forum.audacityteam.org/viewtopic ... 49&t=64936Audacity02 wrote:I saved the sample I recorded into a WAV format file. Should I attach it in this area? Do I use the Upload attachment tab?
Audacity02
OK Steve.
Will it be useful to attach a screen print of my Audacity starting screen in addition to the WAV file?
Joe
Joe
Audacity02
Hi Steve,
I hope this works OK. I am attaching the WAV file and a screen print of my starter screen in Audacity.
Joe
Joe
- Attachments
- ScreenHunter_18 Dec. 04 01.12.jpg (103.86 KiB) Viewed 1285 times
Audacity02
Steve,
I only saw the screen print get attached, so, just in case, here is the WAV file.
Joe
Joe
- Attachments
- Laptop Record Test.wav
- (566.16 KiB) Downloaded 51 times
Looking at your screen capture, I can see that you’re trying to record streaming audio through your microphone, which might not even be plugged into your laptop! No wonder nothing gets recorded!
Please, follow instructions as shown on this page, and make sure you select either WASAPI or "Stereo Mix", "Wave Out", "Sum", "What U Hear", "Loopback", depending on availability as an “Input Device”.
Note that the drop-down from which you can choose the “Input Device” in Audacity has a “microphone” icon to the left of it. This should not make you assume that all recording inputs must be made from the laptop “microphone”. In your case, you need to choose either WASAPI or "Stereo Mix", "Wave Out", "Sum", "What U Hear", "Loopback" from that drop-down.
HTH.
Cheers,
Robert
HTH.
Cheers,
Robert
