When you type, press ENTER twice every few sentences. Otherwise what you write is unreadable.
What exactly was the problem to begin with? That you could not start Audacity?
If you open "Computer" and put "*.AUP" (without quotes) in the Search box can you find all your AUP files? You may have to double-click on the drive first, search there and then if you have more than one drive, click "Search again in Computer".
I would suggest downloading the 2.0.5 installer from http://audacityteam.org/download/windows and run it with the "Reset Preferences" option enabled. See http://manual.audacityteam.org/o/man/fa ... html#reset .
We can't help you if you can't download. Do you still have the 2.0.5 installer on your computer? Look in the Recycle Bin. It's called "audacity-win-2.0.5.exe".
will not download
- Quality Assurance
Re: will not download
