My mic is recording system audio and I don't want it
Re: My mic is recording system audio and I don't want it
I am not quite sure, but, from the pictures, it seems that the black connector of the AKG microphone is a mono connector. On the other hand, the red connector of the Logitech microphone is a stereo connector. Could this be a factor?
That's because the Logitech is an electret mic and as such it needs to be powered. The "extra" connector provides the power,Robert2 wrote:from the pictures, it seems that the black connector of the AKG microphone is a mono connector. On the other hand, the red connector of the Logitech microphone is a stereo connector
The AKG microphone is a dynamic mic ans as such it does not need to be powered, so it does not have the extra connector.
I still don't know if you're using a laptop.
SupaaaFamicom
I'm using a laptop: asus k53s.
The only mic I could find it's near the webcam, so on top of the screen.
Thanks Robert2 for pointing that out!
SupaaaFamicom
A friend of mine lent me an adapter that changes the jack from mono to stereo, unfortunately the results were the same...
At this point rather my "sound card" suxs, or my mic is flawed
I think the problem is more likely to be with the sound card than the microphone.
It may be worth checking that you have the best available drivers installed for your sound card. See here for some guidance: http://wiki.audacityteam.org/index.php? ... ce_Drivers
