It's very very very simple: The crashes occur immediately after clicking to remove the black split line.Gale Andrews wrote:If you record or import then generate silence at zero (as I assume the poster does) or at the end of the track, a split line is produced.
The poster saysSo presumably any number of the effects that the poster listed have been run across that split line (or across the removed split line). Which is it? A crash immediately you remove that split line after generating silence? Or a crash an hour after removing the split line? If so, why do you attribute the crash to the removed split line?Crashing after clicking to remove the black lines occurs mostly after a session has lasted at least one-half to one hour; sometimes longer.
Or are you removing that split line an hour later?
I can usually click the line to remove it safely for the first 30-45 minutes without a crash. After that, the chances of a crash increase rapidly after clicking black line to remove it. During the sessions, a lot of importing or recording, exporting, and a lot of effects might be used.
Sorry I was not clear in my initial description.
Also, I am very conservative: I don't update unless it's mandatory. If something is already working, why "fix" it?
